Jetting Sanity Check
2001 YZ125 PC pipe FMF spark arrestor
top end with about ~10 hours
I had a lot of oil running down the back of my silencer after my last few rides. Temps in the 50s maybe low 60s elevation 1500-4000 ft.
Was running:
Main: 460
Pilot Jet: 22.5
Needle:#3 position
Today i tried out the procedure in the jetting sticky to test the pilot jet. I could not get it to idle at all running what i listed above. So i changed the pilot jet to a #20. Now i can get it to idle. Temp about 75 about 200 elevation.
The manual says:
59-77 F
Main: 460
Pilot Jet: 25
Needle: #3 position
86+ F
Main: 450
Pilot Jet: 25
Needle: #3 position
So i am a little concerned about how lean i am on the pilot. But it seems like if i can ge it to idle pretty nicely can't be too off.
I am sure you did this, but did you adjust your airscrew when playing with the pilots?
Really, i would not be worried. Bikes don't seize from lean pilot jets. I have also had weird jetting come in to play when using a s/a silencer.
Yes i did. Just seemed strange to be so lean on just the pilot. Just concerned because in the fall i siezed my motor, then i was running main: 450 and pilot: 22.5. I think it was lows 80s high 70s. Don't want to repeat that. Just have never been able to get it really dailed it so far I feel like.
incase anyone wanted the procedure, from the jetting sticky,
Turn the air screw all the way in, then turn it out 1.5 turns to start. Start the engine, and turn the idle screw in until you get a slightly fast idle, or hold the throttle just barely cracked, to keep the engine idling. Turn the airscrew slowly in, and then out, until you find the point where the idle is fastest. Stop there. Do not open the screw any farther, or your throttle response will be flat and mushy, and the bike may even bog. This is only the starting point, we will still have to tune the air screw for the best response.
Now is the time to determine if you have the correct pilot installed in your carb. The air screw position determines this for you, making it very simple. If your air screw is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet.
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
