rm 125 cylinder
sorry for so many questions guys buti was wondering if you can bore out a rm 125 cylinder or does it have a special coating? i was just wondering because i plan on getting a wiseco flat top piston and a phathead cylinder head. also how come i can not find a wiseco over bore piston for this bike?
when you bore most modern cylinders they need re-plating.
also, for the big bore, they need to be ported otherwise they dont run well.
you can run a non nicka-sil coated iron sleeve........if you want your bike to go back 30 years in technology, contact eric gorr he has good prices on big-bore suzukis, it may end up being more worth it to you to go that route rather than trying to piece your own big-bore kit together
im not trying to build a big bore. i was just wondering if i can bore my cylinder out to a .20 like i did when i rebuilt my yamaha blaster or do i have to send it to a special shop?
it can be done, it just won't have the nicka-sil coating which helps transfer heat, and adds longevity.
or you can bore it and send it out to be re-plated
the choice is yours
ya i will just have bored than replated
