Tank swap? will the plastic E fit an S?
i tried searching and found nada.
so, will a fuel tank from a drz-e (plastic) fit on a drz-s?
Yes it can be done ( I have the IMS 2.6GNCC tank for E on my S) but you have to fab a "T" bracket for the rear of the tank out of aluminum and order#3 in the diagram with the hardware to mount the tank. You also need to relocate the horn (this is where bracket #3 mounts) and loose the fan or go to a slim computer fan.
Be aware that two (2) #3 mounting brackets are used with the E tank. You'll also need #18 to hold the rear of the tank. Not sure what mounting the S/SM uses so you may have to improvise some.
You actually do not need #18 to adapt the E tank on the S. Eddie posted a neat pic of how to secure the rear of the E tank on a S frame by simply using two small metal strips a while ago but I can't seem to find it.
Each strip is held in place by the bolt that was used to secure the rear of the S tank to the S frame on one end and by the E tank screw #19 on the other.
The setup looks like an inverted V and I think accomplishes the exact same task as smpapish's T bracket but with little to no fabrication.
I stand corrected...
Sounds like a plan, and a solution.:thumbsup:
http://www.thumpertalk.com/forum/garage.php?do=viewattachment&attachmentid=39062
kinda like this.
