mikuni boost connection
What is that connected to the boost pipe on my Mikuni carb ? Some type of booster is guess. What is it actually doing ? It's up the front near the exhaust outlet.
We are going to need a picture to know for sure what you are talking about. You are probably referring to the exhaust air injection system. US/Canadian models do not have it.
PAIR Valve more than likely as Noble said
Yep, PAIR valve (pulsed air injection) air is injected into the exhaust to clean up emissions. Causes no performance loss, but the air going into the exhaust will cause mad popping if you put an aftermarket can on it. Evidently this popping goes on all the time, but the stock muffler, well it muffles it :thumbsup:
Is the pair value able to be removed if I decide to put an aftermarket exhaust on in the future ?
it's generally recommended, as it makes re-jetting the carb easier and tidies up the engine of the bike
see this thread for details: http://www.thumpertalk.com/forum/showthread.php?t=601726
