WR250 Problem Revving suspect Power Valve
Well I did up my WR250 cosmetically and a couple of issues internally in the engine and now it won't rev out. Previously to the work the engine performed really strong except I was getting water in the gearbox.
Externally I changed the chamber from an gnarly to a stocker I got off ebay for a 2006 engine.
Internally I had a replace the waterpump seal and had a little help from a friend with a 360. Unfortunately he jumped the gun a little and started removing the left cover assembly as he was under the impression he needed to install the waterpump seal from the other side. To do this he took the left power valve cover and pulled the ball joint off the lever and counter shaft. After trying for a while to release the cover we realised it didn't need to come off we bolted the cover back up and replaced the seal from the outside. Then we bolted everything back up. To our knowledge nothing had chenged in terms of the counter shaft from the governor to the power valve. Everything went back together easily
Now when I rev the bike it revs kinda slow and then stops about half thru the usual revs band. About same engine speed everytime it stutters and won't rev out. Riding it and the low end is fine but it doesn't transition to the peaky band it used to have. Just bogs.
I've replaced the fuel with fresh, checked the plug. Am I looking in the right place? Also if theleft cover is going to have to come off why does it come most of the way and then just stop?
After i did my top end i noticed the power valve was sticky from pulling the bushings out, if the power valve won't move before it moves the spring, then something is tight. Also check to make sure you have the alignment dots lined up on the gears between the main and the two outside valves.
I ended up putting an old screw into the the outside valves and using my drill and spining them to create some play so they would move freely.
If you were too ham fisted with the little plastic connecting rod you may have cracked it. Did you you run the engine with the power valve cover off to watch the powervalve engage?
Try taking the stock pipe off and make sure the one you purchased does not have a restrictor in it. Try the old pipe and see if it revs out. I have seen some Euro Stock pipes have a baffle right where it goes to the cylinder. I think this was on a 125 pipe but check it.
Took the right side cover off and the Power Valve seems to be working fine. As the revs climb the valve goes from all the way shut to fully open based on the adjustment on the right side. I put a fresh plug in and gave it a run but still something holding it back. I'll pull the carb off tomorrow to verify I have no problems in there.
I was aware of the restrictor that is in some pipes but this one doesn;t seem to have anything on it. I suppose I'll try the old gnarly to see if it runs.
raisrx251 was on the money. Pipe seems to have some sort of honeycomb like a cat. converter in the bend nearest the radiator pipes. Even jetted to suit the pipe it runs like a dog up high. I have no idea how they would sell them like this is the markets where it is needed.
WOOHOO..I got one right!! There was a guy on here who had a 125 that would not run right and kept fouling plugs. I swore that the problem was it was flooded so bad that he should tip the bike up and spin the back wheel in 5th gear. Well I was wrong and felt like a fool..
Do you think there is a way to cut it out of there, the one I saw looked like a factory worker just tacked it in there right where it goes into the cylinder. It is a shame to as the stock pipe is a excellent pipe. If you are looking for a low end pipe a U.S. pipe like the FMF fatty. I think HGS, CRD are more top end pipes.
Have a mate at work planning to attack it this weekend with a dremel and then oxy-weld or mig it back together. Studying the weld burn pattern on the pipe it seems you might be right about it just being tacked in place. He'll just have to cut that whole section along the factory seams to get at it.
  • Similar Content
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit: www.RockstarEnergy.com
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - https://www.rockymountainatvmc.com/docs/Brake switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
    • By Ride
      ...thought this might be fun as i see a lot of older guys riding Huskys on TT. I'll start...
      41 years old - 93 TC610/99 WR250/02 WR250/04 TE450/04 CR125/06 TC250 (on the way)
    • By Dave Hoder
      I'm just putting the finishing touches on my streamlined version of the BOZZA DRAFT shop manual for the 610. I've removed everything but the english language & made it easy to find what you're looking for. I re-wrote the part about the computer with many thanks to Xfool but I'd like a little proof reading here. In particular I'm not real sure about the Service Interval section. If any of you would be willing to double check what I've got here & report back with any errors or omitions I'd be greatful. (I added another section on adding & removing screens) Also I don't know if it's legal to post this for public consumption but I'd be happy to share it with anyone who want's a copy.
    • By Agitator
      10/17/08 UPDATE! I posted more photos on page 2. Not all pictures are on page 1. I will constantly be adding more photos as I go along.
      Many of you have heard of my starting/idle problems with the 610. Carburetion has been ruled-out time and time again. I sensed something else was going on. The engine has never wanted to idle down, sounded like there was a load on it even in neutral. Since I had metal filings in my oil when I first got it, I have now decided to overhaul it and make everything ship-shape. It turns out that I was correct- there is some valve damage that I will talk about later.
      I don't like to take apart dirty engines and get the dirt inside 'em
      A little gross.
      My cleaning station:
      A little better now
      Clutch removal:
      after removing springs
      bottom of pressure plate
      everything looked decent as far as wear
      after removing plates
      basket after removing hub
      Area after removing basket.
      Removing the starter gear with snap ring pliers
      More to come. I'm uploading pictures of the case splitting, etc...
      I'll try to ease off on the photo-over-obsession. The next batch of info/photos will be a little more interesting.
      Comments and suggestions are appreciated. I'm already ordering parts from George so before I know it, I'll be just waiting on new parts (after a little more cleaning.
