top end job
got a 04 KX 100. dropping a wiseco in it. should we hone the cylinder or is it plated? i heard that you can ruin it if its plated.
Lightly deglazing will not hurt the nickasil coating. Don't overdo it.
Scotch-brite pads work great.
That's what I do as well. Scotch-Brite pad with lots of ATF.
You can safely hone a plated cylinder with a ball hone. The aluminum oxide materials used in standard hones is incapable of cutting Nicasil (Electrofusion on pre-'03 Kawies) plating, but it will de-glaze the bore surface.
Do NOT use a spring-loaded finger hone. The stones can snag in the corners of the ports and chip the plating.
After you de-glaze the cylinder, if the cross-hatching is not clearly visible, the plating is worn out. There are no tools that a typical homeowner possesses that can cut new cross-hatching into a plated cylinder. It must be cut with diamond tooling.
Use a scotch brite thats what I do on all my plated cylinders
  • Similar Content
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By 02YZ426
      I thought it would be interesting to see what everyone in this forum is riding... So post them up
      Here's my 2006
      And my buddies 1996 KX250 that I just finished fixing up. Motor completely rebuilt and ready for the track.
