How to check the oil
I was wondering how you check the oil level on 93 cr 250 im new to two strokes , Ive tryed looking online and read about a bolt you pull to see if it comes out. But i dont know thats why im asking.
Do you want to just check it, or totaly replace it?
Its probobly easier just to drain it and add some fresh oil.
For my 99 I dont have a dipstick so I unscrew this bolt (not sure what its called) but I unscrew it and tilt the bike to the right. If I tilt it a lot and nothing comes out,that means Im low on oil.
Do you have a manual?
the bolt is called a check bolt and it is located on the same side that you put oil in, just dont get it confused with the collant drainage bolt.
