fcr35 questions
This probably sounds like a dumb question but, what is the screw that is in the bottom of the carb(fuel bowl) and what effect will it have on the bike by turning it either in or out?
Also what is the screw that is under the mainfold on the air box side and what effect will it have on the bike by turning it in or out.
Thanks.
It is the pilot screw. It fine tunes the pilot/idle circuit in conjunction with the pilot jet and slow air jet. It is for idle only
Which one is the pilot screw, the one next to the main air jet under the manifold or the one in the bottom of the carb?
I suggest looking in the manual for details or perhaps the parts fiche or Sudco catalog. Kind of hard to make sure I explain it in a manner you would understand without pictures.
