wondering about oils ? let me know
I was wondering if there is a difference between engine oil, and trans oil, can i use the same oil in my trans that i do in my engine ? or is there a special kind of trans oil ? and how often should i change the trans oil, just as often as the engine oil ? let me know :thumbsup:
There are different kinds of oils, you can use the same in both, as long as it doesn't have Moly (good for engine but too slick for the transmission side)
Change your trans oil every 10ish, wouldn't hurt to change it when you change engine oil, but its not really neccesary.
im running the kawi s4 10w40 oil in both engine and tranny side, is that ok ? if not what should i run in the tranny ?
yes, just as long as their is no moley. honda make a oil made for the tranney, that works good
If you want to save money use shell rotella 15w40. You can find it at walmart for about 8.00 a gallon. It works fine in both. :ride::thumbsup:
Yes same oil in both. I personally use a 15w40 diesel oil. Shell Rotella T 15w40 is great, as well as the 76 Lube Gaurdol 15w40 I have recently been using. These oils are around $2.65/L when bought in 5 gallon pails.
If you want to use another oil, use a 10w40 non synthetic motorcycle oil such as Pennzoil or Castrol, these can be found for around $4/L
Make sure you are changing both oils after every good hard ride. In these bikes fresh oil is super important. Change your oil filter every 10 ish hours.
alright, thanks for the help guys !
+1 on the shell Rotella
I use the full Synth Rotella in my 998 Ducati and it's never given me a problem.
Also use the 15-40 in both sides of my CRF250R (engine/Trans)
what is moley???
what is moley???
moleybendium or something like that, its a oil addtive that causes clutch failure
good info
its a friction modifier, in vehicle oils, NOT good with wet clutches
hp tranny oil in the red bottle is good stuff, the crf is almost the same tranny as the cr
Use any good oil, in the clutch side use oil that is wet clutch compatible ( it is labeled like that)
Change it alot. After every race day or long day of practice, If you get it overheated, or slip the clutch alot. Dump it in between motos or as soon as possible.
these machines kill oil when used under race conditions. Casual riding can get by longer.
is that the energy saving thing???
moleybendium that is
I dont think so.
Molybdenum is a friction reducer and used as an oil additive. It is not good to be used in the trans side because it causes clutch slippage.
I just changed the oils and filter for the first time on my crf, now using Motul 5100 10W40 in both sides of the engine. Is this oil ok for my engine and tranny?
while on the topic of oil i have read a few threads with people saying they use more oil than is stated in the manual, i have an 08 crf 250 and in the manual it says 700cc in the engine and 600cc in the tranny. should i use more?
I use Honda Hp4M oil in the engine and Honda Hp4 in the transmisson.
Hp4M is the silver bottle with molly
Hp4 is the gold bottle
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
