Get that dancing monkey off your back! Read more... ×
can someone tell me how to set my sag on rear suspension
I was just wondering what the sag should be set at on my 450 when sitting on it and when not sitting on it, any help would be awesome
100mm sag is what i run on mine. slightly under 4 in. you should have 25-35 mm of free sag as well .
just wondering if your looking for numbers or how to adjust the sag or both
how to adjust the sag ......do i measure with and without me on the bike? and if so what are the numbers
thanks for replying
thanks for replying
I found this at racetech.com
Q: What is "Race Sag" (Static Sag)?
A: Static Sag or Race Sag is the amount the bike compresses from fully extended, with the rider on board.
Here's how to measure it.
First extend the forks or shock completely and measure from the wiper to the bottom of the triple clamp on forks or from the axle to a vertical reference point on the chassis. This is L1.
Take the bike off the stand, put the rider on board in riding position. Get an assistant to balance the bike or have the rider hold onto something, comress the suspension about 25 mm (1") and let it extend very slowly (slowly is the critical term). Where it stops, measure the distance between the wiper and the bottom of the triple clamp or the axle and the reference point on the chassis again. Do not bounce. This is L2. (If there were no friction in the seals the bike would come up a little further.)
Next lift up on the suspension and let it drop very slowly. Where it stops measure again. Do not bounce. This is L3. The reason L2 and L3 are different is due to stiction or drag in the seals and bushings. (If there were no friction in the seals or the linkage the bike would drop a little further.)
Half way between L1 and L2 is where it would come to rest with no friction. Therefore L2 and L3 must be averaged and subtracted from L1 to calculate true Static Sag.
Static Sag = L1 - (L3 + L2)/2
To adjust Static Sag make longer or shorter preload spacers or use the preload adjusters, if available.
It is important to note that there are no magic Sag numbers. However here are some guidelines to use as starting points.
Rear Sag 95-100mm mm
free sag 15-25mm
to adjust, use the rings on top of shock spring.one complete turn is about 5mm
hope this helps
Ernie
