Help. Rear wheel/tranny kx80 locked
1998 Kx80. Owned for about a month. Ran fine until today.
2nd gear, trail riding, 13 year old rider(gf's kid) in front of me, rear tire locks up, slide/skidding to a stop.
"what's up?" i ask. "Dunno. I think the brakes are stuck?"....
Turns out, clutch in, or out, the motor/tranny won't let the chain or rear wheel turn.
For basic diagnostics, I pulled the chain: Rear wheel free wheels fine, and the rear brake works fine and doesn't stick.
Chain back on, bike in first, clutch in: wheel locked (chain goes taught when pushing bike, wheel won't turn.
bike in nuetral (I think... can't be sure, as the rear wheel/front sprocket is STILL locked) same results...
Tried that in all gears with the same result.... I ended up having to carry the rear end and walking the bike about 2 miles... good GOD am I gettin gold... you'd have thought I carried a 200lb man several miles instead of 1/2 of a 120-is lb bike!!!
Since we've owned it, it's been a little hard to get into nuetral once it warms up.... but I've had lots of bikes like that over the years....
ANy ideas? I'm thinking it obviously has to be a tranny issue, as it starts and runs fine... until you put it in gear and let the clutch out....
Maybe it is the trans but I have seen the lower rod bearing lock up the motor and act like this. You can't get it to shift because the gears are not turning to go into each other. Try bumping the bike backwards a few times and see if it unsticks. Sometimes the rollers in the rod bearing flatten and then roll like a sprag clutch and the more foward you go the tighter it gets and a little bump backwards frees it up . This may not be your problem but I have seen this many more times than the trans causing this.
Sorry. just reread you post and now see that it runs fine, my bad. Must be the trans and now it is time to split the cases. Good luck
Dang. That's about what I figured.
In 37 years of riding, I've never split the cases for a problem. Done it to do some mods/upgrades, but never for repairs....
Well, thank god I have a job w/lots and lots of free time :thumbsup:
rmantoo you may want to search my threads, a while back I put up 2 that have a lot of pics on splitting and reassy a KX250. These may be helpful too you.
I would pull the right side case cover and check the shift mechanism first. Always start with the simple things first. Could be something bent or jammed.
I always tell my son, "Working on them is half the fun."
Good luck.
Just got finished pulling right side cover, and everythign tehre appears to be fine.
Started pulling the motor: pulled the exhaust, then drained the oil, then the coolant: The coolant was pretty much 50/50 mix of brown water and sludge!
Pulled the carb/airbox, and then broke 2 12mm craftsman sockets on the engine mounts, and then broke a 12mm wrench, too!
Off to the hardware store.... IMPACT sockets, YEAH BABY!
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
