Settled the pink wire mod once and for all
I posted this at CRFsOnly, but figured that some people here might be interested as well.
I have my 250X with the following mods:
CCC airbox, screen removed
JD Jet kit, 165/42/red on 5th clip
Heavy O-Ring
fuel screw 3/4 turn out
I have a stock exhaust that has the diffuser removed, and I just got a brand new 250R exhaust system.
I am going to Marietta Motorsports tomorrow, and I will try different combinations with the two headers and two cans I have, as well as the pink wire on and off.
This shop is run by Craig "Huey" Stewart and Chris "Opie" Caylor, both having a long career in racing and tuning for various AMA teams. They do great work, and Huey is going to give me some dyno time and we will see what pipe or combination of pipes works best
And we will see if the pink wire makes more or less power, both in peak power, but also in power per unit of time.
I will post up the dyno charts and all the results tomorrow night.
Part Deux:
Ok, the results are in!
My tuner forgot to email me the dyno charts, but I will post them up later.
We had two 250X's on the dyno today. Huey's is a 2007 250X, but it has the full CCC mod done to it per Honda's instruction. One thing that differs, is that he has a prototype M4 full exhaust race kit on it instead of the 250R pipe.
My 250X's specs are above, but we found that it was running a tad rich, so we moved the red needle from the 5th clip to the 4th and that made the motor happier.
I found that my bike made more power everywhere with the R exhaust kit, compared to the modded stock X system and the X header/R can combo.
Once we got the best setup for each bike, we did back to back dyno runs with the pink wire on and off.
First off, Huey's bike made 3HP more than mine on top due to the R cam, while mine made 2HP more through a good chunk of the mid-range.
But when we did the pink wire mod to each bike, each bike made about 2HP more in the 10-12k RPM range. When you see the dyno charts(as soon as he remembers to email them to me), it is very clear that the pink wire does more than just increase the rev-limiter, because the extra power is being made in the 10-12k range, and not the 12-23k range that the rev-limiter extends.
So there is a definite increase from timing or something else, and it had the same proportional increase with both the stock X cam and the R cam.
I will post up the dyno charts as soon as I get them.
Good work!
Scientific results are always more useful than anecdotal speculation.
Very good info thank you. I have moved to a more open riding area.. I will be looking for power in all different places.. I am glad I put my pink wire on a toggle switch.. Might be time to try er out again :thumbsup:
hmmm, i never felt that big of a gain when I pulled mine
Well, it may depends on your particular motor, how it is jetted, what other mods you did, etc...
But we tried two different bikes, different years, different mods, different cams, and in both cases, had nearly the same result.
great info! It would be cool to see the stage 1 hot cam added into the mix with the different combos you mentioned.
Did you use a street tire or knobbies on the dyno?
Knobbies, we wanted to use the same tires we would be riding with. The bike was strapped down very well, so there was no slippage.
When it goes in for the first valve check, I am having that cam installed.
Couple things you can see here.
One is that the R cam makes a decent increase on top.
And you can also see that the 250R pipe is an improvement over stock. While peak HP does not go up much, it also doesn't drop off as fast.
Not huge gains, but clearly there is something going on with the pink wire other than increased revs.
with the 06 it says that with the pink connected and the R header, and X can it made .10 hp less than the full R exhaust and pink disconnected? Is that right?
Do we now conclude from your '06 numbers that the X muffler gives more hp and torque than the R muffler? And keeping the X can and pink wire connected makes you lose .10 hp, but gains you .17 in torque? :thumbsup:
It looks like the "green" set up, but with the pink wire disconnected would be the best set up, or am I missing something?
you guys need to look at the BIGGER picture here. Yes the green setup may offer more Hp and Tq for 100 rpm....but the blue setup provides for 1-2 more Hp from 9K rpm and above!!!!
I'm interested to see what the numbers would be with the green setup and the wire disconnected. Would it be better than the R can? It's possible that the bike works better with the X can.
very true. I was just remarking on this specific graph.
That's a good point. I also want to see the stg 1 hotcam numbers with the different exhaust set ups compared to the R cam.
I would love to see that as well. I wish I had a free day that I could go and do that.
Here's the missing dyno picture:
:ride:
Eight years,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,hmmmm.
Edited by YHGEORGE
  • Similar Content
    • By bob_slinger
      I enjoy riding flowing single track and double track with some small technical sections, nothing insane. I'm also way too cheap to spend thousands of $$$ every riding season on maintenance and rebuilds. I've owned a dual sport 1987 XL185 that was underpowered but predictable and a 1991 YZ125 that was overpowering and exhausting in technical stuff (though I'm not a fan of 2-stroke exhaust and noise).
      I'm 6'1" and 200 lbs with riding gear.
      I've narrowed down my choices to Honda CRF250L (heavy and underpowered but low maintenance), Honda CRF250X (smooth power but expensive maintenance), Husky TE250 (smooth power and easier maintenance than CRF250X), Husky WR125 (super light weight and easy maintenance but 2-stroke) and KDX200 (cheap, lightweight but 2-stroke).
      I realize that the CRF250L is more road oriented and closer to my vintage XL185 - I'm considering putting on more aggressive tires and raising the bars. I like that the CRF250L engine has a 8,000km service interval though it is greatly underpowered. I don't mind trailering a bike, so road worthiness is not a deal breaker. I'm concerned the CRF250L will be cramped for my 6'1" size and I've read that the rear suspension is too soft and sags significantly for anyone over 180 lbs.
      The CRF250X seems like the best choice for single track and woods riding but I've read that rebuilds can be expensive and complicated. I've ridden the CRF250X a few times and it feels slightly bogged down at lower rpm.
      The TE250 frame and design look easier for rebuild/maintenance and people have said it is more agile (I've raced mountain bikes most of my life so I appreciate a maneuverable bike).
      I'm only considering the 2-stroke WR125 and KDX200 because they are super lightweight and should have a smoother power delivery and better low-end grunt than my old YZ125 on the trails. I'm not a fan of the sound or smell of 2-strokes but if it makes the riding experience that much better I would consider a 2-stroke.
      Hoping to get some feedback before the spring riding season.
    • By JacksonDRZbeast
      I am currently in the thought process of purchasing a crf250x and converting to supermoto to get it registered for road use. Just wondering if anyone has converted and what tips you would have for me to maybe make it easier? I already have a set of SM wheels off my drz that will fit with new spacers.
      Any advice will help!
    • By GregWB
      Has anyone fitted grease nipples to the rear suspension component and swing arm to CRF250X? Compared with my old XR350R, is ain’t a step backwards not being able to grease the CRF.
    • By Kaito Sutton
      So I’ve got a 09 crf250x and from every angle I’ve been shouted that the airbox mod will be the best thing in world along with a jd jetting kit. At this time I’ll being using the stock exhaust, so I’m wondering if doing these mods will void the registerablilty of the bike. I’m in nsw Australia. Also, anyone with experience with this mod, does it make it louder? As that is the main issue with getting is registered. I’m planning on doing the mod this afternoon so if someone could let me know ASAP that’d be awesome  cheers
    • By MNThumper250
      I'm tearing down my '06 CRF250X for winter prep. I checked the spark plug (see pics).
      I've rode with this plug for most of the summer. I'm thinking it's a bit rich, so for the other 250X owners out there, what jetting are you running/what do you think I should run? The only mods I've done is install the JD Jet Kit (165 main, 42 pilot, Red needle 4th clip, and thick o-ring), FMF Q4, and 4" x 4" hole in air box (with No Toil Super Flo Kit). The bike seems to run alright, but should I drop a few on the main jet?
