03yz250 clutch slipping problem
Ive replaced the plates n springs with a ebc kit. It still slips at high rpm under a load, ei deep loam or pavement. I use honda hp gear oil. Ive used this oil for 15 years and never had any problems with clutches.Its not my cable because I dont have one, its hydralic,yes the cylinder is releasing fully.Any suggestions will be greatly appreciated,thankyou
When did you first notice it sliping, before or after the hydralic? Did your old plates look worn? Did you replace all the plates or just the friction plates?
is there an adjustment on the end of the pushrod at the basket?
You could try shimming your springs for a bit more preload. The crush washers off old spark plugs work well for most bikes.
Thanks for the input, but its gonna take a lil more then that.My springs are shattered.Any idea what caused that? They're only a few hours old.My guess is ebc had a bad lot of springs but i could be wrong.
