XR650R graphics kits...Hard to find!
I have searched the threads and old posts lead to manufacturers that no longer supply aftermarket graphics/seat covers for the Pig. Has anyone recently purchased some, and if so, where can I find them? Thank you!
I found some through the TT parts store. I really wanted to get stock type, but all I could find were Factory Effex. It takes a while paging through the Tucker Rocky catalog that it links to to find them.
go to hondaparts-direct .com for oem decals, much cheaper than bike bandit i think on most everything. also 00 - 07 should be the same so you can make a 00 look like a 07 lol
check out dennis kirk,they list graphics from FX and FMF.
Check out invisionspowersports.com
thats were i plan on ordering mine after this riding season
AMR can fix you up. Thier eBay store is probably the easiest way to find them.
Don't really like their "std" designs for the XR, but they'll do a custom, "one off" set of anything you can draw/provide/design/think up (for the right $, of course) & that's kinda cool.
I'm happy with the XR's Only kit. Its made by factory effex i think.
AMR on Ebay. Their bomber girl is so hot and looks killer on the BRP.. Made for it for sure. I have a larger tank and it still looks factory sexy.
I personally think that al bakers xr's only graphics are great looking. and well priced at that
Does anyone have a picture of the XR's Only graphics with a Clarke tank? I have the bigger tank and don't know how the graphics kit will look. Anyone with cool looking graphics that are still availabe post pictures.
I'd also like to see graphics with the Clarke 4.3 tank. I'll have my Clarke installed as soon as the smog block-off kit arrives that I ordered a few minutes ago from BD.
Luckily i was at Chaparral sale and foudn some for the R for $25 each and bought a set, i shoulda bought all 6 sets and sold here to help those out. there nice
Show us a pic!
I want a set if they rock like u say.
Thanks and have a dirty day! :busted:
I got around finally to designing some custom graphics. These were put together by Guts Racing for $159. I hope they are of highquality and worth it. The colors when printed will be a bit more realistic than what you see here.
  • Similar Content
    • By mrdsee
      ~177 Titanium bolts, nuts, washers etc leftover from various motorcycle projects. XR650, YZ 125, YZ250 a mix of new and used once hardware.
      Made by Mettec
      Over $2k worth of hardware
    • By Xr600guy
      So I don't seem to find my specific issue so here I am asking.
      I have a 1997 Xr600r. It was recently re-jetted and has ran really well ever since until more recently it has begun to have this issue.
      Everything works fine. Kicks right away, nice and easy. Runs great, sounds great, purs. But when I'm downshifting and slowing down to a stop, if I let my hand off the throttle that's when it just dies. I found that I can counter this by lightly holding the throttle as I down shift (so I'm revving quite a bit during downshift).  But it hadn't done this before.
      The only thing I've done that I suspect may have been an issue on my part was when I pulled out the engine to change the valve cover gasket and upon doing so perhaps when connecting the carb back to it, I may have missed something or made a crack in the boot?
      Any ideas? Thanks
    • By Kenya
      Hello all,
      There's been a lot of talk about how to register a dirt bike in states that don't allow it.
      I just moved to North Carolina and for the first time in my life might be able to afford a bike. I've been dreaming about an XR650R for a long time, but they're not cheap. Plated bikes seem to be more expensive too. So here's my question, has anyone tried to plate a dirt bike by adding all the necessary features and having it inspected as a custom bike? Anyone know of another way I can plate an xr650 in NC?
    • By Jsmoot
      Hoping for some help before I throw in the towel and end it all!
      Engine starts fine, runs and idles well for +/- 10 minutes, but cuts out while riding once the engine warms up (175 - 185) and intermittently cuts out thereafter (any speed/gear). It will start up after 30 seconds or so (but won't run for long before dying again). No spurting or surging.. just dies.
      I've replaced CDI (twice), Spark plug, spark wire and coil, and most recently pulse generator. I do have a 41mm Flat side carb from a CRF (and it has more power than the old carb setup), breathing through a Uni filter. Also, sealed battery tender battery (hasn't shown low when trickle charged).
      What's next on the test/replace list? Stator maybe? Please help...
    • By Richard Stevens
      I found a buddy that’s going to help me with the “Dave’s Carb Mod” after that what size jets should I order before we begin? I’m in Cols Ohio and 1140 above sea level. Should I just order the Dyno kit or FMF kit or should I just go to jets r us and order 2-3 from there? Thanks all so much help. Love it. Stay safe out there.
