WR360 Two Much?
I’ve been lurking here for some time (since an around-the-block ride on a ‘99 WR125), not knowing if Husky was going to stay in the USA or not; and now it looks like they are committed, especially with BMW now behind them – good news for us.
In considering their off-road models (I prefer the previous body-style due to my size), the 125 is intriguing due to light weight, though with the desert and high mountains I ride, it may leave me wanting for power; the 250 certainly has the right amount of power, though a close-ratio trans is not my flavor, so it’s out; the 360: seemingly buckets of power to spare, yet is there too much pull for a 5’-9”, 155lb, super senior? I have confidence in my throttle control – don’t need the adjustable-cam throttle tubes, but I don’t want my next bike to tire me out with tugging like the Gas Gas 300s/big-bore KTMs four strokes I test rode. The 360 is rare as are most Huskys in the Southwest, so a test ride is out of the question..
What are your thoughts, especially from those who have ridden/owned both a 125 and a 360?
Mods: sorry; I believe this is Husky specific.
Oh Wally!!!!!! Chime in here. OFG
I might be of some assistance.
I own a '01 WR360 and an '07 WR250. I have previously owned an '04 EC300 Gas Gas.
The 360 is a great recreational bike (this is why I can't bring myself to sell it). The 250 has a fantastic engine but I wish it had a 6 speed even though I wouldn't use it for 95% of my riding. If the 250 had the 6 speed I would probably sell the 360.
I have raced my WR360 but feel that the WR250 is a better race bike because of the fatigue factor eluded to by the original post.
I do not think a Gas Gas 300 is a tiring bike to ride. It is smoother than either Husky. I sold my Gasser because I got a great offer by someone who wanted it allowing me to jump to a new bike for a small sum extra. I find the Huskies are more fun to ride but I'm probably slower in a hare scramble than on the Gasser. Gas Gas bikes are just so smooth.
IMHO if you think a Gas Gas 300 is tiring to ride then I don't think you will enjoy a WR360.
I would consider an '09 TE310 or if it is more than internet rumour an '09WR300 Husky. (I know I'm intrigued)
Regarding the seat height, I'm shorter than you and feel more comfortable on the earlier shorter seat height bikes (I in fact swapped engines between my bikes for this reason), but I can't really think of an instance while riding where I found the seat height of the '07 to be an obstacle. I've ridden the same nasty trails on both frames without feeling a significant difference.
I love my WR360, and certainly think it is the cats meow in the desert or sand type situations. But if fatigue from having gobs and gobs of constant torque on hand are a concern to you then it probably isn't the bike for you. I also have an 06 WR250 and also think that I am probably faster and less tired riding it, especially in the really tight crap that is filled with rocks and downfall. The ability to ride below the hit and have no fear of grabbing to much throtle at the wrong time is less tiring. That said with a 360 it is really easy to get lazy and just keep it 2 gears higher and dare it to stall(not possible). Just remember that the 360 is a big bore and if you dial it in you need to have it pointed in the right direction no matter the gear or speed.
My oppinion is to wait for the WR300 in 09 IF it comes with a 6 speed or true WR 5 speed, or you could do like OFG did and install the 6 speed in a current WR250 and have the best of both worlds.
I am 5' 8 or 9" depending on daily variable spine tilt and I don't have any issue with the current seat height. I changed my 06 to the old style tank and plastic because I like the narrower feel and increased tank size without the "bulge" or width of the new style tanks.
Thanks guys.
Yes, the GG 300s tugged too much for my liking, compared to my former RMX, which at first seemed odd as I was under the impression they'd (GG) be smooth, and they are; it's just there's a relative bulge of fat, thick torque down low that doesn't fit my style. Others seem to cope/exploit it; either I couldn't use it properly or adapt and therefore it worked against me in tight areas with rocks & mud. And both dual-stage ignition settings were not obvious either. I must be getting too old, or don't have a feel for that. Bye 360!
I guess we all look for certain characteristics in a bike and this performance delivery was not for me, so many thanks for pointing out the 360 would not be favorable; ya know: it should have been obvious but new bike blues can make one blind!
I did like the GG full Ohlins setup - best yet!
Mostly I miss the slimness, lighter weight, better suspension and mid-RPM snap of my former Suzuki so the WR250 should be closer. And if I had to get a newer one (doubtful) then I'd convert to the older plastic for sure, though I could use and desire a true WR trans found in the '00 or '01 as a 6-speed trans for the conversion would be difficult to find.
I've done a whole lot to my KTM RFS (351cc kit, conventional forks, RevLoc, LHRB, etc.) to make it do better every where, though it still has some of that what I find odd KTM-handling/feel, moreover is not as thrilling (scarry) a ride as a lighter smoker would be. Maybe I should keep it and get a Husky as a second bike, either the 250 or a 125.
Thanks again for bearing with me while I ramble out loud.
Wally will have a true wide ratio 5-speed just laying under his bench. Just as soon as he gets the gumption to put his other six speed in. OFG
You might want to consider the Gssgas 200 also. It has very smooth power and will not tire a person out like a 300 but still has more down low then the 125. They also fit somone under 6' better. They can be found real chep which is a plus. The only thing I don't like about them is they are heavy.
Conside the WR125 also. I am 200 pounds and it has all the power I need in really steep terrain.
  • Similar Content
    • By asweeba
      I unfortunately broke my turn signal switch today and can't seem to find any available other than bike bandit. It's part of the left switch cluser on the handlebars.
      The part number for the switch cluster is 800099721
      Bike bandit is the only vendor that has it and it is retailing at 125 dollars! Anybody know where I could get a used one or another for cheap?
      Thank you for the help!
    • By flabiturbo
      Good day, I need help, I have a husqvarna fc 250 2014, when it is on it goes up and down the acceleration. check for tps and it says 4.7v / 4.8v. but when I want to adjust it moving it as it is commonly done. Nothing happens. always remains with the same voltage (4.8) that I can give solution?.
      Buen dia, necesito ayuda, tengo un husqvarna fc 250 2014, cuando esta encendida sube y baja la aceleracion. chequee de tps y dice 4.7v /4.8v . pero cuando quiero ajustarlo moviendolo como comunmente se hace. nada sucede. siempre queda con el mismo voltage (4.8) que solucion puedo dar?
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By Mike Michel's
       Would anybody know how many watts my 99 TE 410 stator
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit: www.RockstarEnergy.com
      Source: Husqvarna Motorcycles GmbH
