big bore jetting help
I am putting an Athena big bore kit on my 2006 KX 250F. I will probably have to change jetting. Has anyone done this mod and know what jetting to use??
Thanks-
It will be trial and error but here is what I am running on my 07 with Hot Cams.
178 Main
45 Pilot
JD Red needle #5
50 Leak
1 3/4 turns on fuel screw
Try Dvns start point then read the kx250f jetting 201: sticky
It'll explain how to get it right..
Thanks-
What kind of fuel do you use?
Thanks-
93 pump
