Motion Pro Spanner wrench
Was wondering if this wrench will fit my 2003 YZ125 rear shock locking and adjustment rings? It says it fits most offroad and atv single shock applications. Also fits 87mm and 68mm locking rings.
Can any of you confirm if this wrench will fit?
I am guessing the smaller end is for the steering stem nut?
Most of the wrenches are for doing bench work on the shock as there is too little space on the bike to normally fit it in .
On the bike you should use a hammer and a punch with the end ground to fit the contour of the locking nut so it does not beat it up too much .
