05' Stalls At high RPM?
When riding it and you hit WOT in any gear, it just dies. almost like you hit the killswitch? Other than this the bike runs awesome, just cant hit high rpms...
Thanks
Whats your jetting? sounds like you're running lean.
You may also have debris in your floatbowl to where when you're at WOT its generating enough vacume to pull it into the jet clogging it untill the needle goes back down unclogging it agian
Could be TPS or CDI... Try disconnecting TPS and test. Does it still die?
