piston size?
hey im wondering if a piston that is .010 oversize will fit in my standard bore cylinder? i guess im just asking if that small of an amount will be t tight,and also what is the differance and how can i tell if i would need an a,b,c,d size piston,thanks 03cr125:excuseme:
anyone?? is .010mm to much oversize to fit in a standard bore cyl. bueler bueler anyone anyone?
I believe any amount oversized, you must bore accordingly.
yeah i figured i just wasnt sure if they had slightly larger for more wore cylinders as the site i wanted to buy parts from asks if you need a b c d size pistons ??
