help with my 110
How does it run ? If it run good , then leave it alone .
If you run low rpm's most of the time the outer ring on the plug will always be black .
It's the electrode part you gotta worry about .
the hole thing is black . it idles great with choke on and off , only problem is it bogs when given gas fast full throttle . thinking i mite need to turn the fuel screw in maybe a 1/2 or 1 turn ?
How does it run at WOT? Does it bog or sputter?
To set the pilot mixture screw:
1: Start bike and let it fully warm up.
2: Turn up the IDLE SPEED screw to a high idle.
3: Adjust PILOT MIXTURE screw for highest RPMs.
4: Re-adjust IDLE SPEED screw for normal idle speed.
