any difference in pipe dia on the header between rs-2 and rs-3
as question above for the drz400sm everyone recommends rs-3 on here but dont like the idea of doing away with the passenger foot thought of the rs-2.
You don't have to do anything with your footpegs with the rs3. Its the TRS TI made for the E model that you have to use the footpeg mounts for.
You will have to make some changes back there. Don't know if you can keep footpegs or not. But the RS-2 requires no changing. The RS-3 is designed for the E, just like the Ti.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
