Feel like a moron for asking
I know the info is here, I am just too giddy to spend hours finding it right now.
Just got the Yosh Ti TRS and installed. Have to flatted the pipe to clear spring, no biggie. Hits radiator in front, no biggie there, I will just smush the rad a bit and bend it upwards. When I get the stroker motor installed with the spacer, what will I do then?
Thanks!
Pics??????????????
Pics??????????????
I already ripped it back off, had to figure out where I wanted to weld on my O2 port. Gotta do that at work tomorrow.
Oh, this thing makes the Akrapovic look like a girly pipe!
Spacer for stroker kit on barrel is 2.5mm..tap on rad for some additional clearance.
you can do several things.
some bike evne with the spacer,there i no issue.other make pretty good contact.
you can flatten the rad tank some,move the rads up,etc.
its pretty simple to make relocation brackets for the rads.
I think all mine will need is some persuasion with a hammer. If I am feeling really special when the time comes maybe I will make some brackets, or a slick little concave insert for the tank and weld it in.
