Jetting or Oil Miixture?
I have a 2007 Suzuki RM125. I have alot of excess oil coming out of my silencer. It runs out and down my silencer to the where it ends and drips all over my swingarm, brakes, etc. I am mixing the gas to the manual specifications which is 30:1. I am a trail rider and I don't rev the bike out as much as a racer would (is this the problem?). My current jetting (stock) for a Mikuni TMX38S carb is a 370 main jet, 42.5 pilot jet, needle clip position 3, and air screw 2 turns out. I think that I might be mixing too much oil in the gas, due to the fact that I'm not revving the bike out so it doesn't really need all that oil. I was thinking about mixing it 40:1, but I am not sure if jetting would be an issue after changing the oil mixture. I am at about 500-1000 feet elevation (depending where I ride) and at 65 degrees F or about 18 degrees centigrade. Can you help me out?
Change your jetting, not your mixture, start with your pilot and drop it 1 step and reset your airscrew accordingly, then move to the needle and the main. Your not going to hurt anything, unless you make drastic changes
Spooge is more of a byproduct of not generateing enough heat
Let me also say that when the bike is in the high rpm's for 10-15 minutes straight, no spooge comes out of the silencer. When I ride trails, though, it pours out.
My bike did not spooge when run hard but would when i was on the trails, i rejetted and it got better then i bought the JD kit and it got even better. Make sure you change out your silencer packing before you start jetting, mine was soaked with residual oil( to the point i could wring it out) so it looked like i was still getting spooge
I just got my carb back today and swapped out the 370 main for a 360. I also tweaked the air screw a bit. I seem to have alot less spooge coming out, but it is still there. I would say I eliminated the spooge by 60%. I think I just need to ride it harder and it will be fine.
Bump... One question though... It doesn't smoke at low rpm's, but if it has been idling for a little bit (15-20 seconds) and I rev the bike, it produces heavy smoke in the high rpm's. No smoke when it is constantly run at high or low rpm's though. Is this okay?
Yes:thumbsup:
