Drz400s Headlight Bulbs
Can You Use Headlight Bulb With More Wattage Than Standard.
With Out Causing Any Damage To The Bikes Electrical System.
I Need More Light.
You sure can, I am using a 90/100 without any problems. It won't be road legal though.
I see all the guys here who want HID and more power and brighter light and before I jumped on that wagon I did my research and found an expert at Daniel Stern lighting.
Google Daniel Stern Lighting.
He recommends a replacement bulb found here:
The thing is, it's not about how much brighter the light appears to you that matters, it's all about what actually lights up the road and makes things visible to your eye. Just because HID appears brighter doesn't make it better.
For those who wish to read more:
twomany: those sites are very informative.
So did you end up going with the recommendation? Is there a noticeable difference?
Where can you get a 90/100 bulb?
I've got it on order. I emailed Daniel Stern and got the recommendation, you might see if he can help you on the 90/100 bulb. Check his site for contact info.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
