Swing Arm bearings
Do you have to get the swing arm bearing pressed in and pressed out.
Yes or you can use an appropriately sized socket to drive them out. I just brought my son's CR 85 swing arm to my local dealer and they pressed the old ones out and the new ones in. Done.
they're pretty easy to get out with some threaded rod, washers, nuts(not yours) and a socket.
When installing new bearing put them in a freezer for an hour or two and they'll go in much easier if not little effort.
I actually have more bearings in my freezer than I do food!
