Tools for fork inner chamber oil change (06 125)
Well in your first post that is the same tool I have, the msr tool. Your 2nd post is basically the same tool as the msr tool except its just an adapter tool with out the slot. The slot is nice for holding part of the forks while you work on them. You will also need a 49mm wrench which im not sure if the one you posted is 49 mm or not? As far as a seal driver you do not need one unless you are replacing the seals. If they are not leaking I would not tear them apart. A 17mm socket should just be a standard tool you have to work on your bike, nothing special.
Thanks for your response.
What about the 3rd tool I posted?
That's the most important tool isn't it?
If you want the best tools available, try this thread.
PM Lowedog and see what he has. His prices are good, but his tools are superb. They are made of aluminum (well made) and are soft enough that they wont scratch up the fork caps. I bought from him on ebay before I realized he was TT member.
That cheap 4 in one tool on ebay will get you by, but it sucks.
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
