S Engine - whats this cable for?
Hi guys - I'm in the process of swapping my dead E engine for an S.
Can anyone tell me what this cable is coming out of the S - I can't find any reference to it in the manual and my E doesn't have it. Could it be something to do with the sidestand kill switch?
Here is the connector at the end:
I don't have time to check but it is likely the neutral light switch/indicator. The S is the only one that had it.
Not the side stand kill switch for sure.
The wire going into the white epoxy is for the neutral light. An E does not have this. You cannot put it on an E engine without swapping the shifter drum, but a S engine in a E you can simply leave it be or swap the blanking cover from the E engine to the S one. Be sure to remove the contact pins and springs if you do.
Excellent - thanks for the swift reply.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
