rear brake problem
alright, i just replace the rear brake pad this afternoon.
when i ride out to my destination, along the way, i'm feeling the bike sluggish, true enough, i found out the rear disc is somewhat "seize" by the pad..
after settling my stuff, which is about an hour later, the wheel still doesn't spin freely, however, i just ride it back
when i reached my new destination, rear wheel is still as "seize", caliper and disc is also damn hot
so, i remove the entire caliper, pad, and pump out both piston (but not removing it out entirely), suspecting could be some dirt that is causing te caliper not "floating"
so, i clean up the caliper and both piston really well, even the 2 "slider" which suppose to allow the caliper to "float" the rust was remove and grease up.
so it was tested and seem to be working (floating)
assemble and do a test ride in carpark, no issue, rear wheel spins freely.
this evening, i rode out again. purposely use more rear brake than usual
and i reach my place, without any problem (tested wheel spins ok)
when it is time to go home, i purposely use more rear brake again, this time, along the way, it starts to feel alittle sluggish again, shitzz..
when i reach home, tried spinning the wheel, it somewhat "sieze" again
what could be the problem??
i flush the flush about 2-3mth ago (from a opened bottle)
do ya think i should flush and replace the fluid again?
could it be the brake fluid property breaks down after twice it was been boiled over?
:thumbsup:
Did you use after market brake pads? They seem to run thicker than OEM pads for some reason. I would flush the fluid again though if you have boiled it twice. I prefer Motul. It seems to stand up to the heat better.
i would take the master apart and check to see there isnt something hanging the pistons from moving back in after going out.
was it a challenge to get the new pads in? pushing the calipers pistons in?
might be the source of the problem
chris<pixelmonkey>:thumbsup:
