HSC adjustments help
Well Factory Connection helped me out with adjusting the stock suspension settings of my 2006 CRF250R to my weight. I set up all the clickers right except have a question with the high speed compression red nut. They told me to go 3 turns out on the knob. Problem is, im not sure how many 1 clicks is. Is it one whole turn of the nut from where the punched dot is 3 times or does 1 turn of the entire nut equal more than 1 turn? Do you understand what I mean, its kinda hard to explain.:thumbsup:
thanks.
3 turns out mean turn it clockwise all the way in, then turn it 3 turns (3 times 360°)out, that's it :thumbsup:
