Urgent Help Needed
This is not really jetting but i did not know where to put it but my clutch is slipping and I heard that you can put washers on the clutch springs to help fix the problem. Will that work or what do you suggest to get my bike going?
I would suggest putting the post into the bike specific forum or the general forum. You will get a better response. If your clutch is slipping you can first make sure the slack on the clutch cable is adjusted right, it needs to fully disengage. If that is OK you probably need new clutch plates and or springs. The clutch is more than likely slipping because it is worn out. I have heard that in a pinch you can take the steel plates out and rough them up with sand paper clean them and that will give you a little more clutch life.
