Range of Jets
Greetings - I've just purchased a 2008 XR6 650 L for some dual sporting in the Olympic Mountains. This bike will augment my 2005 Yamaha WR 450 F which I ride around the logging roads behind my house.
I've read the FAQ and a bunch of articles. Could someone let me know what would be a good range of main and leak jets to purchase as I tweak the stock jetting. I've ordered the manual and will be opening up the exhaust a bit, going to a foam filter, and adding knobbies. I understand the FAQ talks about a suggestion for jet changes but I'm wondering what range might be best to order. I believe Dave's mods calls for a 55/158 starting point (without modifying the exhaust.
I also wanted to ask where is the best place online to buy jets? And does AIS make a smog removal kit for the XR 650 L?
Thanks,
Keith
Pacific Northwest
Why did you choose the foam filter? I'm considering the K&N because it seems to be lower maintenance. I clean & re-oil the foam filter on my CR250 after every ride, is this same level of maintenance required for the 650 foam?
I ordered my jets from Motorcyclecarbs.com - I think Kenzo recommended this place, & the style too... anyway here's what I ordered, probably overkill but:
Remove SKU Name Price Quantity Ext. Price
681 KEIHIN MAIN JET 99101-393 #158 6.95 6.95
682 KEIHIN MAIN JET 99101-393 #160 6.95 6.95
680 KEIHIN MAIN JET 99101-393 #155 6.95 6.95
683 KEIHIN MAIN JET 99101-393 #162 6.95 6.95
679 KEIHIN MAIN JET 99101-393 #152 6.95 6.95
801 KEIHIN PILOT JET N424-26 #52 7.95 7.95
802 KEIHIN PILOT JET N424-26 #55 7.95 7.95
803 KEIHIN PILOT JET N424-26 #58 7.95 7.95
HTH..
Thanks clintp! I appreciate the part numbers. I went with a 55 pilot and a 158, 160, and 165 main. I plan on opening up my exhaust and am thinking the 165 might be the best place to start. I plan on using Dave's Mods.
I ordered the UNI foam mostly because I'm very used to foam filters on motorcycles. I'm sure the K&N will be fine. I use a K&N on my Harley. I've K&N filters on my tuned Corvette and have used K&N for years. Some think the finer dust associated with dirt bikes might make foam better. I buy that argument.
I notice you didn't buy a 165 main jet. May I ask what main jet you're currently running? And have you opened up your exhaust?
BTW I ordered Dunlap D908 rally tires in a slightly wider back 130 vs 120.
Keith
I too ride in the Olympic forest! I have yet to see another XRR out there and I go every weekend. Let me know if you want to go ride sometime.
EDIT: Errr that's a 650L you have there eh. Oh well its all the same the offer is still on the table.
Yep, that would be cool to hook up. I'm working now to get the L dirt worthy. I also have a WR 450 F when I need some crazy fun. But the thought of riding up into the mountains is why I got the L. Please sent a PM and maybe we can do some fireroads!
