650L to a 230L?
Becuase of gas and perhaps my personal safety, I'm considering going down to a 230L. Problem is, I tried a 230F before buying my 650 and I didn't like the way the bike was a PITA to start and get warmed up. Ironically that's what I love about my 650, BAM starts on a dime every time and is ready to go almost right away. Got to be the best starting bike ever made.
The jetting on the 230f was lean, thats why they are hard to start if the jets are not changed. The 230L is the same but for $15 in jets and a half hour to change them and you are set. I have ridden Engines Only's 230L test bike and the thing is a blast. They have a cam and a 250cc piston kit and the thing gets about 80 miles per gallon.
ur worried about gas on a 650L?
:thumbsup::p
i think u will be very disappointed stepping down from the big thumper
unless the 230 is a commute bike..
I f it is for commuting and light trails. Go for it. I have a 230 and it is easy to start and light wieght, and peppy.
I have a CRF230L and i love it . starting was a little tricky untill I changed jets and modified the exhaust and air box lid. Now it cranks the first time every time. When I bought my 230L I looked at and sat on the 650 and did not like it. I'm sure the torque is awsome compared to the 230 but it's size and weight turned me against it. I hear the kawasaki 250 dual sport is awsome.
I have a 230 I put a Wiseco 11:1 piston and high lift cam and it starts first yime every time jetting is key.
hey, guys and gals,
You 230L riders should check out this link, very, helpful.
http://www.hondacrf230l.com/index.php:thumbsup:
I currently own both bikes myself. I ride the 650l on the street and the 230 in the woods. The 230 is much lighter and easier to handle offroad
I agree,it is very fun off road. If by chance, you lay it down like I have, one person can get her back up. Most of the time you can handle it, when it tries to get squirely.
What kinda of mileage do you get with th 650? What year is it?
Heh heh heh. Eeyore's angling for a trade :busted: A lot of people who ride their Ls on the street can't resist the power of the 650 so they go the other way.
Yes I am. Looks like I will have 2 bikes, this spring. If this one does not sell, I think I will mod it out. For more fun on the trails.
The bigger one will be for mile munching!
Ohh that would be a good choice, it rocks to have room/time/money for two bikes :busted:
I was confused as to why you're both trying to hop up and sell your 230 at the same time.
I would like to sell it. But have had no calls on it. Which I sort of thought would happen. There is a DRZ local that I wanted to try and buy.
I had planned to do the mods, now anyways.
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
