replacing the clutch
can i just buy new cork plates if my clutch is starting to slip, or is it neccesary to replace the entire kit? (cork plates, steel plates)
Yes, you can replace just the drives "corks" if, the steels are still with in Honda's specification, not wrapped or heat checked. Scuff them with Emory cloth or a 3M to remove the glaze.
However, replacing the entire clutch pack with heavy duty spring, will ensure that there will not be premature clutch ware.
A piece of mind goes a long way.
Good luck!:thumbsup:
57 minutes ago, wazzabie said:
What makes the EBC clutch pack better then the stock Honda?
I don't know, I've always been satisfied with Honda frictions, but I'm now using an EBC 091 kit in my XR218 and the springs are a lot stiffer than stock, so far so good.
