What throttle with 200x carb on big bore 100?
  • 4 years later...
I used a throttle cable off a cr85. There is a cable that works from like 95-200something cr85's. Thats the one I used.
But the adjuster on the twist throttle is adjusted almost all the way out. The cable needs to be about 3/8" shorter. I called Motion Pro and they said that if I can get them the stock CR85 throttle cable Honda pn# and the length I need changed they can make a custom one for around $35.
