03 450 Piston
i just changed mine on the 02 a few weeks ago. had about a 100 -120 hrs on it. everything was still within spec. i should have waited longer. it was a waste of money, but now i have piece of mind on how it is holding up. keep a check on the valves and dont worry so much about the piston and rings. make sure you change the oil and keep the air filter clean.
compression tests might not be a great diagnosis unless you disarm the compression release.. just a thought.. they say that if you watch oil consumption you should be able to tell when your due for a rebuild... mine doesn't use any over several rides so I might pull it apart and check it out. I bet it will still be in specs but I probably will jump the gun and freshen it up for next season even still.
Ă—
Ă—
