TTR125 pipe change
Also check for flux leakdown. If you are still using conventional spoke oil, consider a synthetic.
NorCal - I like the stiffer piston spring idea. I use a straight-rate #16 ACME spring for my TTR - I didn't mention it before because it was too trick. Now that the cat is out of the bag, I guess we should share the info. ๐Ÿ™‚
Do a search on this board for "jetting" or "jets" or something and you will find out what you should be running. These guys are just screwing around now but they know a hell of a lot on these ttrs. As for trick mods, two words: Heisenberg Compensator. 'nuff said. ๐Ÿ™‚
ร—
ร—
