WR/YZ Clutch Springs
ok ryan, first you have to tell us what year your WRF is; then, whether you believe that the pull is heavier than a YZF; and finally, is there a problem getting it into gear (e.g. clutch properly adjusted but not engaging completely) or some other issue?
note that there is a "washer fix" for WRF's which reduces pull...
https://thumpertalk.com/bike/ubbthreads/showflat.php?Cat=&Board=UBB10&Number=403623&page=0&view=collapsed&sb=5&o=7&fpart=1&vc=1
but first i suggest that we figure out what your problems are before applying random solutions.
jim aka the wrooster
Actually My WR is an 01, and Right now I really need reduced clutch pull. I have noticed sometimes it feels like my clutch is dragging. I currently have a friends DRZ clutch perch and lever on my bike with a Motion Pro T2 line and the pull is 10 times better that it was before. Please let me know if you think I would benefit from the upgrade, and what exatly needs to be done.
get a beer.
click "search" in the page header.
type in "washer fix", change "date range" to "all posts"
press "submit"
read and learn while drinking beer.
you could start here...
https://thumpertalk.com/bike/ubbthreads/showthreaded.php?Cat=&Board=UBB10&Number=111932&page=&view=&sb=&o=&vc=1
and
https://thumpertalk.com/bike/ubbthreads/showthreaded.php?Cat=&Board=UBB10&Number=113635&page=&view=&sb=&o=&vc=1
you can do and undo the "washer fix" in about 15 minutes, total. just watch out that you don't drop the little guide pin that helps aligns the clutch cover -- it will roll under your workbench and it will take you like 10 more minutes to find it. 🙂
The YZF clutch springs are longer than the WRF clutch springs. I did not notice any real difference in clutch pull. But I also found that the YZF springs did not fix my grabby clutch. The washer fix did fix my grabby clutch but I still seem to have to use the quick adjuster on he clutch perch quite often to aliviate my grabby clutch problems.
Ă—
Ă—
