Airbox mods / removal bad for performance?
This guy thinks so, and he says why.
Cant bring it up. Bad link.
Interesting. I think TT must be auto-editing my posts. It inserts ******** for the name of the website.
Yep, looks that way. Maybe they dont want that site referenced?:thumbsup:
PM me the link and I will see if I can link it.
Hmmm. I get the same on PMs. Let's see if they don't want people to write "California Scientific web site (have to google) -> Motorcycles -> Articles (way down on menu on left) -> Resonant airboxes"
Nope. That seems OK:D
Copy and pasted the website. You are right TT does not allow calsci pages for some reason. :thumbsup:
Motorcycles have had air boxes holding their air filters for decades. However, in the last couple of decades the purpose of these air boxes has changed quite dramatically.
Originally the air box was just there to keep flying dirt, rain, and bugs from directly hitting the air cleaner. They were simply an attempt to keep the air cleaner a little cleaner a little longer.
In the '70s, the US government started making noise regulations tighter. At some point, the manufacturers realized that the noise from the air intake was part of their problem. They started to look for ways to muffle not only the exhaust, but the intake roar too. Sound waves are pressure pulses in the air. Pistons pull in air on their intake stroke, creating a low pressure pulse in the air box. Then on the compression, power, and exhaust strokes the intake valve is closed and the air box is free to return to atmospheric pressure. These alternating low pressure and normal pressure pulses are sound waves. The manufacturers needed some way to dampen them out.
Your exhaust mufflers are made of a series of open chambers connected to each other by tubes. The exhaust pressure pulses get caught in the chambers and bounce around in them, then have to leak out relatively slowly through the tubes. The math that governs mufflers can also be applied to air boxes: you need a big chamber to hold a bunch of air, and an inlet tube to let air in at a controlled rate.
The air in a box is compressible, so a box is the acoustic analog of a capacitor or spring. Air has mass - about 1kg / cubic meter, about 2 pounds per cubic yard. In a tube, the air moves back and forth as a slug, as long as the frequency of the movement is small compared to (tube length / speed of sound). So, at low frequencies a tube is a mass term. Since the speed of sound is about 1000 feet per second, a foot long tube is equivalent to 1 khz. 10,000 rpm is 160 pulses per second on a V-Twin, so "low frequency" clearly applies on an air box for any snorkel shorter than about 6 feet long. A wire screen is the acoustic analog of a resistor. It slows air motion, converting the energy into heat. The combination of a box and tube is a system with a resonance. Exactly as a child's swing has a resonant frequency, exactly as a ported speaker enclosure has a resonant frequency, so does your air box.
A system at resonance is nearly perfect - there are small frictional losses in any system, but at resonance these are the only losses. Imagine pushing a child on a swing - it takes very little energy to keep her going at the natural frequency of the swing, just a little push each swing is enough. The only thing slowing her down is air resistance and a little friction in the chains. So at resonance, air flows through a tuned air box almost without resistance. This is as close as we can get to a superconductor of air.
A modern engine with valve overlap will naturally have a dip in the torque at about a third to a half the red line rpm. If the air box is tuned to have minimum resistance to air flow at this rpm, the dip in the torque curve will be partially filled in by the ease of pulling air into the engine.
So, your air box is most likely designed to add horsepower in the mid-range. The air box will have little or no effect on peak hp.
Years ago, before airboxes were designed as resonant systems, it used to be popular to cut additional holes in the air box to allow more air flow for high rpm. This is no longer a good idea. Modern air boxes can flow much more air than the engine will ever use. Modern engines have throttle bodies or carburetors with throats that are typically about 45mm in diameter, about 16 in area. The inlet snorkel to a modern air box will be roughly 300 to 800 - much larger than the throttle body or carburetor throat. The idea that the snorkel makes for a significant impediment to air flow into the engine is questionable at best. Drilling holes to let in more air is exactly equivalent to drilling holes in your speaker cabinets to let out more sound. Removing the snorkel from your air box is the exact same thing as removing the port in your speakers, the tube that's carefully engineered to have just the right diameter and length to reinforce the bass on your speakers at low frequencies. By altering your air box in any significant fashion, you're most likely going to cost yourself three to five hp in the mid range, and gain nothing measurable at high rpms.
Part I: Theory.
Here, from first principles we'll develop the theory of how an air box and an inlet tube form a coupled spring- mass system with a resonant frequency.
air box volume = V
inlet pipe = area * length = A * L
Air Mass = 1.25g / 1000 cc
Atmospheric Pressure = 104kg / cm sec2
PV = nkT (Ideal Gas Law)
If the air in the inlet tube moves X cm into the air box, then the volume of air inside the air box changes to:
V' = V + AX
Since Boltzman's constant and the air box volume don't change, that leaves only the temperature and the pressure. The gamma for air is 1.4, so
T' / T = (V' / V)^.4
T' / T = (1 + AX/V)^.4
We'll presume AX/V is small, so (1 + AX/V)^.4 = 1 + .4AX/V
The number of atoms in the air box changes to n' = (1 + AX/V)n. So, the new pressure is:
P'V = (1+AX/V) nk (1+.4AX/V) T
P' = (1 + AX/V) (1 + .4AX/V) P
P' = (1 + 1.4 AX/V) P
Now we can find the spring constant of the air box, K:
Force = Pressure*Area = Kx
Kx = 1.4 AX/V * A * 104 kg cm / sec2
K = AA/V * 146 kg / sec2
The mass of air in the inlet tube is
M = AL * 1.25g / 1000
The resonant frequency w, in radians per second, of a spring-mass system is:
w = sqrt( K/M )
= sqrt( AA/V * 146 kg / sec2 * 1000 / 1.25g AL )
= sqrt( A/VL * 146*1000*1000 / 1.25 sec2 )
= 1000 sqrt( 116.5 A/VL ) / sec
The resonant frequency is w / 2pi, and the resonant rpm is 30 * number of cylinders * f. For a V-twin, rpm = 60 * f.
f = w / 2pi = 160 sqrt( 116.5 A / VL )
resonant rpm = 4775 sqrt( 116.5 A / VL ) (single cylinder)
resonant rpm = 9550 sqrt( 116.5 A / VL ) (V-twin)
resonant rpm = 19100 sqrt( 116.5 A / VL ) (4 cylinder)
Part II. Applications.
Here we'll examine a particular design, and see if we can understand the purpose of the design.
On the Suzuki V-Strom, the air box holds approximately 8 liters, about 8000 ccs. There's an inlet pipe which has a 90 degree bend in it. The two sides, inner and outer, differ in length a bit. We'll use their average, the centerline distance, as the length of the pipe. The pipe opening is about 200 square centimeters, and the length is about 20cm. Fortunately, as all these numbers appear inside a square root, our results will not depend on highly accurate measurements. Of course, if you're designing an air box you would want to be quite precise, but we're just trying to understand an existing design, so if we're off by a few percent it won't really matter. We'll also concern ourselves with the flow through the pipe and see if the mach number of the airflow is low enough to ensure linearity.
At 12,000 rpm, the V-Strom's 1 liter motor is pumping 6,000 liters per minute, 100 liters per second. The V- Strom inlet snorkel has an opening of about 200 cm2. 100 liters per second is a column of air 1000 cm 2 wide by 10 meters long, or 200 cm 2 * 50 meters long, so apparently the peak velocity through the inlet tube is less than 50 meters per second. The speed of sound at sea level is about 340 meters per second, so this is about mach .14.
Whenever air flows past something, like the walls of the inlet snorkel, the air touching the walls will stick to the walls and not flow. The air very close to the stuck air will flow, but sluggishly because the nearby air isn't moving. Thus there will be a region of air right next to the tube walls which does not flow easily. This area is called the Poisson stagnation region, named after the French physicist who first described it mathematically. The faster you try to flow air through the tube, the thicker the stagnation region gets. In a narrow tube at extremely high flow rates, the stagnation regions can grow to pretty much fill the tube and the flow through the tube can get slowed quite dramatically. However, mach .14 is not a very high flow rate. This low peak velocity guarantees the Poisson stagnation region on the tube walls will remain thin, and the tube will be substantially open for free flow. We've satisfied the engineers's prayer "Please, God, let it be linear."
The resonant rpm will be 9550 * sqrt( 116.5 A / VL ) = 9550 * sqrt( 116.5*200 / 8000*20 ) = 9550 * sqrt ( 116.5 / 800 ) = 9550 * .38 = 3650 rpm
This number is consistent with the torque dip in a 10,000 rpm v-twin with valve overlap. Remember, we only estimated the volume of the air box and the length and width of the snorkel, so 3650 rpm is just an estimate and is most likely off by a few hundred rpm. Apparently the Suzuki engineers designed an air box which would resonate at the torque dip, thereby giving essentially frictionless airflow at the rpm where the engine was having the most trouble making torque.
If you decided to make substantial modifications to your engine, like high compression pistons, new cam shafts, and re-mapped ignition and fuel injection, you would very likely change the rpm at which the mid-range torque dip happens. In this case, if you can measure the new rpm on a dyno, you could use this information and our formula to decide on a new snorkel length to change the air box resonance to match the new torque dip.
That's deep!
There can be definite advantages to a properly tuned airbox. No doubt.
But we don't know how much Yamaha may have compromised optimal power to meet noise and other design goals in their airbox design.
If better power curves are your ultimate goal, trust the dyno.
we know for a fact airbox mods improve hp across the range from MPfabs dyno testing tho. So while this is in theory true in practice many engines still benefit from improved intake systems/airboxes, however some vehicles don't gain a benefit such as the 5.4l v8 in my truck a better filter helps but an intake system doesnt make a difference
Stock air box = EPA Restricted and less power
Open Mod air box = Add more fuel and get more power:ride:
I know....I know....Pretty advanced debate I have going
here, but just try to grasp my knowledge....:thumbsup:
lol....seriously though. Do you really think the EPA allowed
yamaha to give our little air pump "all" the air it needed.
Do you think they allowed our little motor the exhaust
flow needed without being restrictive? And after all that,
do you think they gave it all the extra fuel, even at
stock configuration for air/exhaust, it needed to allow
for optimal power?
I doubt it.
