08 450 EXC-R Cam Tensioner ?
I see my cam chain tensioner is sweating a little oil. Does anyone know the torque specs for the two bolts (inner and outer). Thanks
2008???
08 is the XCR engine and has one large (like 22mm or larger hex) threaded plug like screw on the right side of the cylinder head.
07 is the RFS engine and has 2 smaller (8mm wrench) screws holding the tensioner on and one (10mm hex) in the center and is located in the left rear side of the cylinder, not in the head
