Spitting coolant
My KTM (08 excr 450) spit coolant while trail riding in the socal desert heat today:foul: . It seems to overheat alot. Is there any serious problems, if so how to fix them?:thumbsup:
My KTM spit coolant while trail riding in the socal desert heat today:foul: . It seems to overheat alot. Is there any serious problems, if so how to fix them?:thumbsup:
ride faster, these bikes need air almost constantly flowing through the radiators, there is the turkey baster mod on here if this will be a usual occurance
it sounds like he may be right.I just got my new 450 EXC-r today & spent the day in the woods in 75-80 degree heat & sure enough it over heated 2 or 3 times.Anybody have any strokes of genius for a fix?
I found out ktm actually sells a small cooling fan through there hard parts catalog. Someone tell me if it works?
Have you rejetted the bike yet, Are you running the stock pipe still, what coolent are you useing.
Is there winter air in you'r tires still Ha Ha.
I out here in Cal City it got up to 110 my bike use to over heat untill I did the changed coolent and ran a over flow coonlet tank, I also rejetted and pipe helps out, The bikes are running hot to pass smog so they can be shipped in country Big brother was wacthing now it in country you can do what you want with it to get run right.
Also out here I normaly riding Wide open there's not much slow riding were I am at.
Motul motocool and it is bone stock
These you'er problem bone stock untill you change those parts you will be over heating They say JD makes a great jet kit, I running Engine ice for coolent and a RLR coolent overflow tank They say you can open you'er stock exhaust can up I running a FMF 4.1 Ti can on mine.
The KTM don't like to sit still at and be running or run at slow sppeds it's a race bike it ment to be moving you can put a fan on you bike, I will one day just to be safe but as long as you'er moving you should be fine if you are going slow let the motor rev in a lowwer gear to spin the water pump faster that mite also help out.
where do you ride at.
Even New bike need some twicking to get then right every brand has it's problems.
Jetting is the first thing to fix.
Stock KTM's are too lean.
The problem is with the needle.
Contact JD Jetting and get their recommendations.
Also do the other mods. for the emmision crap.
The coolant recovery tank is a good idea even if you don't have a over heating problem.
After you do the above mods. and you still have a problem, you may need to install the fan kit. This will require other mods. also to the charging system so it doesn't kill your battery.
Good luck.
I was riding off of Backus Road before Cal City, the temp was about 110
So how did you over heat the bike then I hardly ever get under 2nd gear Wide open I normaly 5 or 6 gear moving unless I riding pass the camping areas I slow it down because of the kids I dont want to run one over they dart out in front of you all the time.
I ride out there evey weekend let me know some time we ride some back road together I ride from my house out there Do yu ride by the water tower across from the prison or by the race track.
i re jetted my 450 exc and it still overheats sometimes. just use engine ice in the radiator and there is a fan you can buy, not sure if it works.
There have been many posts on this very subject recently. Do the JD jet kit, turkey baster mod, factory fan, and either a stator rewind or small rectifier mod.
My fan was perfect in the rocks at Kennedy Meadows this Saturday, and did not overheat. A Yamaha WR450F and my sons Honda CRF250X did though.
Re Jet if you have not done so already. Lean = HOT!!!
Exhaust mod helps, 07 SXF pipe fits wonderfully!!
Swap to some Engine Ice and the KTM Hard Parts fan is your new best
If your crusing kinda slow the fan will kick on for maybe 15-45 sec. Hauling a$$ It will not run, the thing i dont like is that its got constant power, so after you park your bike the fan will most likely come on 1-2 or 3 times depending how hot it is and may potentially drain your battery.
I personally have not had a single problem since the mods, no dead batteries, over heating.... ok i take that back, ive got one problem..... getting rid of this shit eatin grin everytime i ride it!
I have not rode out at Backus Road my self Have you tryed Camalot the old Golf course is fun to tear it up at Or Rosamond Is fun also one side there lot of Whooped out section the other side of 14 Is more wide open type riding.
Watch out for the shooting range.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
