spark pkug wire?
is it possible to remove the spark plug wire and boot from the coil assembly? id really like to put an msd or ssiimilar wire set up on the yz250.
I dont believe you can remove the wire from the coil without cutting and splicing.
so it isn't ur typical screw in wire. what kind of glue. and how does the wire make an electrical connection if its only help in by glue.
The cap screws on the wire, but the wire is soldered into the coil and then glued or covered in rubber.
