Bog
Hey guys i got a 450 x and a 450r and i'm not happy about not being able to snap the gas like my 450r the bike just dies you have to roll into it for it to go. Now i know that you can cut the airbox and rejet the carb and i did rejet
the carb but i wondering about this cam for the carb that motosport sells for 100 bucks that looks like you don't have to do the o ring trick it is a replacement piece. And i also know about putting a 450r cam in the bike just want to know if cutting the air box and that cam for the carb will bring me some snap in the throttle delay. Doug.
1. what is your jetting set as? perhaps it is set too rich... what does the plug indicate? does the bike decel pop upon the easing of the throttle? what is your average riding temperature and elevation?-- I recommend either the JD jet kit or 'Skoot's $25 NCVS kit' for jetting purposes
2. cut the airbox per skoot22's how-to http://www.thumpertalk.com/forum/showthread.php?t=670993 , and remove the baffle http://www.thumpertalk.com/forum/showthread.php?t=485782 and the airfilter's backfire screen once you go with a backfire resistant filter(twinair powerflo)
3. cams have nothing to do with your current bog. if you still desire a cam for snap, here's a cam information spread that i got from AS:
*Originally Posted by AgentSmith
I would tend to agree. Although HotCams are forged as well, it's damn hard to beat the quality of the Honda 450 cam. When's the last time you heard of a Honda 450 cam failing...of any cause???
Here's a rundown I put together with 450 cam info. There is a description of each in terms of what they will yield. Figure out where you want the power to be and choose accordingly.
Honda Cams
Honda 2004-2005 HRC Cam - Part # 14110-NLZ-650
Really strong to top end cam, with a decent mid range, but lacks bottom end.
Intake Lift(inches): .390
Exhaust Lift(inches): .350
Intake Lobe Center (degrees): 110
Exhaust Lobe Center (degrees): 105
Intake Duration (degrees at .040"): 260
Exhaust Duration (degrees at .040"): 260
Honda 2002 CRF450R Cam - Part # 14110-MEB-670
A good all around cam, strong bottom and really strong mid range with a decent top end as well.
Intake Lift(inches): .380"
Exhaust Lift(inches): .356"
Intake Lobe Center (degrees): 106.5
Exhaust Lobe Center (degrees): 107
Intake Duration (degrees at .040"): 249
Exhaust Duration (degrees at .040"): 272
Honda 2003 CRF450R Cam - Part # 14110-MEB-770
A good mid range cam.
Exhaust Lift(inches): .336"
Intake Lobe Center (degrees): 109
Exhaust Lobe Center (degrees): 109
Exhaust Duration (degrees at .040"): 262
Honda 2006-07 HRC & Honda 2005 CRF450R Cam - Part # 14110-NLZ-610 & 14110-MEN-670
Really strong bottom with a decent mid range.
Intake Lift(inches): .374"
Exhaust Lift(inches): .313"
Intake Lobe Center (degrees): 107
Exhaust Lobe Center (degrees): 110
Intake Duration (degrees at .040"): 248
Exhaust Duration (degrees at .040"): 268
HotCams
HotCams Stage 1 - Part #1016-1
Excellent bottom end and midrange increase.
Intake lift (inches): .378"
Exhaust lift (inches): .343"
Intake lobe center (degrees): 106.5
Exhaust lobe center (degrees): 103.5
Intake duration (degrees at 1mm): 237.5
Exhaust duration (degrees at 1mm): 268.5
HotCams Stage 2 - Part #1024-2
Excellent midrange and top end increase, good all-around cam.
Intake lift (inches): .402"
Intake duration (degrees at 1mm): 248
HotCams Stage 3 - Part # 1056-3
More top-end power than Stage 2. Will work well for TT and big bore/strokers.
Intake lift (inches): .409"
Exhaust lift (inches): .356"
Intake lobe center (degrees): 116
Exhaust lobe center (degrees): 104.5
Intake duration (degrees at 1mm): 251.5
Exhaust duration (degrees at 1mm): 265
4. what will also help with removing bog is removing any smog emmissions control device that you may have on the bike. again, skoot22 did a how to on rendering the pump ineffective with jb weld http://www.thumpertalk.com/forum/showthread.php?t=670999 . additionally, you can try the redbeard, AP mod for a more effective burst of gasoline http://www.thumpertalk.com/forum/showthread.php?t=467294
:thumbsup:
