ebay stroker crank
270$ is about retail for the stroker crank.
hotrods wants $374 for the stroker and $295 for the stock stroked crank.
I wouldnt buy directly from Hotrods when you could find a reseller offering it for much less.
I just realized that they also make a stock crank for $295 which I confused for a stroker, sorry.
270$ for the stroker seems like a deal.
Yeah that is a nice deal. I got my +5mm for 295 from lukes.
Can use with Anthena bigbore or only for stock bore?
I think you can use any bore as long as you have either a stroker piston or a spacer so that the piston won't contact the valves or the case. I have the JE kit from lukes http://www.lukesracing.com/luksr/bbkits.html it's the 470 kit with 94mm topend and the stroker crank. 30cc on the crank 40cc on the bore, the spacer route I hear is less reliable because of an added gasket but eddie sells and makes them so I would take his word over any local advise. I had a little binding issue with the stroker piston and the rod but I was able to work it out with a file and it worked fine.
I had bought mine from http://cgi.ebay.com/ebaymotors/_Motorcycle-Parts-Accessories__SUZUKI-DRZ400E-5MM-STROKER-CRANKSHAFT-KIT-DRZ-400E-400S_W0QQitemZ360070530086QQadnZMotorcycleQ20PartsQ20Q26Q20AccessoriesQQadiZ2863QQcmdZViewItem?_trksid=p3756.m20.l1116
. Great item but when i had a problem with the stroker piston they didn't answer me (see http://www.thumpertalk.com/forum/showthread.php?t=570359 )! About yours, it surprises me that they refer "stock piston", you should make that clear! It's impossible to use stock piston with this crank and without a spacer:bonk: !
lol,the spacer is less reliable? classic.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
