Any pre-96 YZ125 owners on here?
Ex NESC/NEMA novice/youth int racer here from the early 90s. I have not had a dirt bike in over a decade...sold my last bike (94 YZ125) in 1995 to buy a car. Have not ridden in 3 years (borrowed an 01 CR125 for a weekend) but a friend with a KTM 200SX (ex Dirt Rider test bike, actually) is bugging me to get back into it.
Back around 2000, I borrowed a 97 KX125 with a full PC engine for a week, and went riding with a friend who had a 99 YZ125 at the time. The stock YZ was noticeably stronger than the admittedly ratty KX, but the KX ergos suited me better than the tall, stiff feeling YZ.
My friend with the KTM insists that older bikes are just plain junk. This is only his 2nd bike - 1st being a ratty 94ish RM125, so I'm not sure he's the best resource on the matter. It's not like we'd be racing...just trail riding and some fun laps on a practice track.
The last 3 bikes I owned were 91, 93, and 94 YZ125s...back when they were new. The 93 was my favorite as it had a super pipey motor with a noleen exhaust, ported 90 cylinder etc and other things I cant' remember. How archaic would an early 90s YZ125 be compared to recent bikes?
Has suspension improved *that* much that a revalved early 90s model would still be junk by comparison for our intended uses? I know peak hp and power delivery has gotten much better, but is it a big deal if we aren't racing?
I was going to tell you that everything has changed a lot, but then I thought about it and no.
I found an old Cycle World magazine in a used book store. They had the 1991 250 MX shootout. As I read the article, I realized that the strong/weak points of each bike was pretty much the same as today's.
I think the current powerbands are a little broader than they used to be. Handling would be pretty much the same, and ergonomy would be a little better due to flatter seats. Suspension would be where most of the improvements would be found, but a revalved mid-90's bike could work good as well.
My main concern with a 10+ year old bike would be general wear. The bike could be really good new, but as any competition machine, time and bad owners can easily turn it into a money pit.
I suggest you find a bike that is not older than 4 or 5 seasons. The new YZs (2005+) and KTMs (2005+) are really good choices if you are going for a 125. They are reliable and fast.
  • Similar Content
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
    • By fiat2nv
      Hi all, First post here. I need some help.
      Ive just bought an 05 yz 125 for a good price but it needs some work. One of the forks has some pretty severe pitting of the chrome on the stanchion towards the bottom near the brake caliper mount.
      Ive found a pair of good condition forks from an 04 yz250 for a very good price, from the research ive done its seems that both the 04 & 05 forks are 48mm but are different, with the 05 fork regarded as being better than the 04, but not as good as the 06 + sss forks.
      Im looking for the cheapest way to get me riding, Will I be able to make the 04 forks work with my 05 triple clamps, brakes, wheel, axle, spacers etc? If not does anyone know what hardware id need to make it work?
      Finally, as a last resort, does anyone know if i could swap the stanchion from the 04 fork into my 05 forks?
      Thanks, Andrew
    • By idratherberiding
      I bought a 2006 YZ250, have ridden it 5 times.  It needs some tuning, but I am not sure I'm keeping it so don't want to spend much on it.
      Has fmf gnarly expansion chamber and turbine core silencer.
      I ride about 1000 feet above sea level.
      I'm going to clean the carb and check the jetting.  What is a good jetting for me?  85 main jet?
      Also check the reeds.  Is there a big difference between getting aftermarket reed cage and reeds or just getting a cheap aftermarket set of reeds that fit the stock cage ie.  Boyesen Power Reeds?
      The other things I'm going to do is permatex all the joints in the exhaust system and a compression test.   It was 220psi 5 rides ago so I'm guessing itll be fine.  Its bogging a bit but I'm thinking its carb and definitely exhaust joint related.
      Let me know if I'm overlooking anything that could make the bike run crisper and more bottom end without throwing much money on parts
