2001 DRZ400S Tool Kit recommendations
Purchased a 2001 DRZ400S about 10 days ago and the PO had lost the OEM tool kit. Should I purchase a new one (if possible) have looked high and low for one. Or, should I put one together myself ??? If I try to make my own, I would really appreciate your help in recommending the most important pieces.
I sold myine in Classifieds b/c i found th eCruz tool kit. It has everything except the 22/24mm axle wrenches and has a sweet divided bag tha tattackes to the fender. OEM tools can run almost $100 from the dealer and Cruz is better quality for about same amount.
I saw a combo 22/24mm wrench but havent purchased yet. I picked up a 22 and a 24 mm 3/8" socket from motion pro.
They also have a Fanny pack version. Their Harley tool kit won best product at 08 Dealer Expo.
I like the Motion Pro trail kit with the folding 1/4" drive t-handle. Small and light, fits in the front cowl, or a pocket. You might want to add sockets, e.g. 14mm, phillips #2, spark plug socket (in case you drown the motor crossing a stream). I carry general tools all the time, and tire/tube repair tools separate from the rest in a fender bag, and only bring them when I go offroad.
Thanks for your suggestions - I had a problem with one of my previous bikes spark plug tool. I thought any good plug wrench would work but could only get it out with the OEM thin walled plug wrench. If I could find the light weight OEM rear axel wrench I beleive I could put together a good tool kit of my own. Once again, thankeyvarymauch
I'm looking for a stock tool kit if anyone has one.
Fender bag not needed.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
