When does the rev-Limiter kick in on an 07 SM?
Does anyone know exactly when the Rev-Limiter on an 07 SM kicks in?
Had my first dyno done on the bike Saturday(Still stock). Wanted to get a baseline prior to adding my FCR MX and RS-2/3x3, the mechanic asked me to find out at what RPM's the limiter kicked in at. Something to do with his Dyno-Max Pro 2000 app.
Will be doing the Pipe and carb next week. Looking forward to seeing the difference.
10 000rpm
You will probably find the rev limiter kicks in just under 10K. mine hits at 9,975.
Your stock HP will be about 33.5, after the mods, about 39.5. LOL, will be interested to hear the results of your runs to see how close my guess is!
Thanks William,
The stock run went 37.7 hp.
From what I hear, your not testing a drz. :thumbsup:
You forgot to take into account the Canadian HP Exchange Ratio :thumbsup:
Thanks William,
well you have your baseline:thumbsup:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
