Two questions; Fuel Mixture Screw & Spring Rates
2007 Husky TE610; need to get recommendation for T handled fuel mixture screw with source and part number, and, what are the spring rates for the front and rear stock on the '07?
Thanks.
You want a brass fuel screw such as Scotts or a brass tipped aluminum bodied one such as JD, avoid like the plauge the all aluminum ones such as ZT or MSR, they are too soft and the tip can break off when you screw it in until it stops, that will not only ruin your day but your carb.
Thanks for the info on the mixture screw.
