computer and clutch
bike: 2006 wr 250 f
symptom 1: computer flashes "EP" and can't be reset?
symptom 2: changed oil, refilled with Yamalube 10w-50, now clutch doesn't work. I can start the bike in nuetral, pull clutch in, shift, then it immediately dies.
another question: I am going to mic the pads. I might drop in new plates...is there any difference between carbon or kevlar clutch plates. Should I replace springs?
thanks all,
rev up the engine a bit, then put into gear, mine used to do that with yamalube, be really grabby. works so much better with belray. also let the bike warm up a bit, get the oil flowing to the clutch
