Transforming the XR400R into SuperMotard for the Weekend !
I found a set of 17" wheels that I can borrow for the week end .
They are comming from a XR650R so the front wheel fitted perfectly but the rear has different size bearings except that I think the rear will fit right there.
There's a race in my area and I'd like to try it with the XR.
Here's a quick view how the bike looks right now :
:thumbsup:
Just for shits and grinns.
See if the XR4 rear wheel bearings will fit the XR6.5 hub.
Rent or borrow a micrometer and measure the OD of each rims bearings or the ID of the wheel bearing sleeve.
It's worth a shot, this way you keep the XR4 axle and it's possible it will mount without any bike changing mods.
I need to keep the XR400 axle since it matches the swing arm , the 650R's axle is bigger and will not go thru the XR400 swing arm.
According to my search .
The XR650R has a 6004 "20x42x12" on the right side and 6204 " 20x47x14" on the left side.
The XR400R has a 6203 "17x40x12" on the right side and on the left side a 6303 "17x47x14".
So I need to switch the rear left for a 6303 "17x47x14" on the XR650R wheel ( easy find ) but the right side is a bit tricky it has to be a "17x42x12" and all I can find with that size is a OEM Honda part number # 91003-KRM-841..looks like the after market bearing company don't carry that size..:thumbsup:
Done.
The XR650R wheels does fit on a XR400R , the front one bolts right on and the rear you swap bearings and use the XR400R rotor on the XR650R wheel.
Here's the final product with a new rear slick and a Supermotard front fender.
I wonder who gave you the idea to use the 400 bearings in the 600 hub?
That fellow must really be smart to suggest such a simple idea to make the swap work!
They are not XR400 bearings , I took the mesurement of both wheels , went online with the dimension needed and google found the part number for me..:ride:
Took me about 15 minutes.
It's good to know that you can fit a XR650R wheels on a XR400R..
..That was a lot of fun , the XR400R ran great.
Next time I'll get a 320mm front rotor , it doesn't work with the stock rotor , not enough braking power..:ride:
No pics to show but I have a small video......clic here....
They are not XR400 bearings , I took the mesurement of both wheels , went online with the dimension needed and google found the part number for me..:)
so, what part number or what part did you need to get, and where did you get it? I would like to know just in case I ever need to fit some xr650r wheels on mine.
Thanks.
91205-950-003 OIL SEAL 25X42X7
91253-033-003 OIL SEL,25X47X6.5
91003-KRM-841 BRG,BALL RADIAL 1
and a 6303 ball bearing.
with these 4 part numbers you can take a 650R rear wheel and stick on a XR400 using the XR400 rear disk(rotor).
To bolt the rotor you need to use 4 bolts part number # 90113-MAC-780 using 4 small washers.
Ive just purchased some xr650r talon wheels for my xr400. Just thought i would let you know that these also fit by changing the 3 rear bearing on the rear to 6303 bearing and they fit straight on.
