ktm 250xcf vs 250xc valving differences
does anyone know or what the difference's in valving are on a 250 4 stroke vs a 250 2 stroke ( 08 ktm xc models)? im trying to get set up an ohlins ttx but only have specs for a 250 4 stroke and thought i could compare the stock valving settings to see what needed to be done for the 2 stroke. thanks.
on the forks 250/300XC and 250 XC-F have the same springs and the very same shim setup
08 250 xcf shock shim stack
21-1
22.30
22.30
36-.25(2)
Piston
40-.20(4)
34-.20
20-.30
crossover
36-.20(2)
26-.15
34-.15
32-.20
30-.25
28-.25
20-.3
Piston
44-.2(10)
34-.15
44-.15
42-.15(2)
40-.15(2)
38-.20
36-.20
34-.20
32-.20
30-.15
20-.3
thanks ktm lew. so does the 250 2 stroke have the same exact valving as the 250 4 stroke?
I believe so? :thumbsup:
like you need to go any faster greg:bonk: coppersmith's might be able to help out,especially if you bought it there;if not there is someone running a ttx on a 08 ktm that they setup i'll try an find the thread :thumbsup:
thanks man. if u find a thread on it let me know.
ktm-lew. do you know what the difference in valving is on the 250 sx vs 250 xc? surely there is a difference there since one is trageted for moto x and the other is offroad. thanks.
lew is saying the exc 4 and 2 stroke have the same valving, the sx will be much stiffer.
yeah the mx valving would be stiffer for sure. i would like know what the valving specs are on the sx.. compared to the xc. anyone know the specs?
Not sure where I found this but here is the 505 BV stack:
08 505 SXF
4-24x.1
1-16x.1
9-24x.1
1-22x.15
1-20x.15
1-18x.15
1-16x.15
1-14x.15
9.5x.3 clamp
16x.25 backer
yes
at least for me it would be easier if you'd say, what exactly you are looking for.
TTX shock or TTX as fork cartridge?
First it was XC/XC-F now an SX as well, where there is a world of difference between those, SX is way, way stiffer
frezno, thanks for reading. after my first question was answered ( difference between 250 xc 250 xcf) i asked another ( difference between 250 xc 250 sx ). sorry if i confussed you. would you care to share the stock valving specs on the 250 sx forks? thanks.
I'm sure there are 2 different stack but ,in earlier forks, I found different spacers, different springs and different stack in the same bike.
so, the first thing I do in WP forks is check those things...
Zac
sure
KTM 250SX/SX-F 2008
Comp
24 x .15 - 4
16 x .10
24 x .15 - 5
22 x .15 - 2
20 x .15
18 x .15
16 x .15
14 x .15
12 x .15
9.5 x .20
16 x .25
Mid
20 x .10 - 4
18 x .10 - 3
16 x .10 - 2
11 x .20
.45mm float
Reb
20 x .10 - 3 (delta shims)
13 x .10
16 x .10
14 x .10
13 x .10
12 x .10
11 x .30
14 x .25
that base looks nasty stiff.....
yeah, all those new SX's are definitely too stiff for us average riders
imho it's more a pro setup for sandy conditions
ktm finally have decent fork hardware but hamper it with stiff valving?? its like they like to finish last in the shootouts?
thanks frenzo :ride:
